Umang.Raj Posted April 25 Posted April 25 (edited) Hello, just tried unigine today, on my lenovo l14 gen 2 i7 laptop, even when im running unigine viewport at lowest preset, or after closing the viewport and also the world, the cpu utilization stays between 20-30% and also gets heated alot. Is there any way to make it better while i just want to visualize and work? edit- found one temprory fix, setting unigine's process in taskmanager to efficiency mode, which dosen't lower the utilization, but does lower the temperature to good level. Edited April 25 by Umang.Raj
shaman2010 Posted April 26 Posted April 26 (edited) Have the same issue. Loaded only "tutorial" world (archviz) Windows 10 Pro (22H2) Intel(R) Core(TM) i7-9700KF CPU @ 3.60GHz 3.60 GHz Edited April 26 by shaman2010
Umang.Raj Posted April 26 Author Posted April 26 1 hour ago, shaman2010 said: Have the same issue. Loaded only "tutorial" world (archviz) Windows 10 Pro (22H2) Intel(R) Core(TM) i7-9700KF CPU @ 3.60GHz 3.60 GHz please tell me if you find a better fix than what I found.
shaman2010 Posted April 26 Posted April 26 It feels like the game engine is constantly calculating something. Apparently, this has something to do with textures. Let's give it some time, maybe the developers will notice and let us know what's going on.
Umang.Raj Posted April 26 Author Posted April 26 59 minutes ago, shaman2010 said: It feels like the game engine is constantly calculating something. Apparently, this has something to do with textures. Let's give it some time, maybe the developers will notice and let us know what's going on. second one looks like a qt function, something related to the editor ui, i think it is happening because of the first one, probably the viewport loop, but im not sure, just installed unigine yesterday i don't know much about it, i got very scared when my laptop got heated lol
shaman2010 Posted April 26 Posted April 26 1 hour ago, Umang.Raj said: ...just installed unigine yesterday i don't know much about it... Yes, it's my second day with Unigine too, so I will wait for the developer's answer. 🙂 By the way, my first attempt was on Fedora 43, but there I encountered a freeze in the material graph editor 5 seconds after opening it.
silent Posted April 27 Posted April 27 You can try to limit FPS by entering console command: render_max_fps 100, other than that there is no other methods to reduce workload. This setting also loaded from the .world file, so it may be overridden an you need to periodically check if the FPS limit is still applied. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Umang.Raj Posted April 27 Author Posted April 27 (edited) 6 hours ago, silent said: You can try to limit FPS by entering console command: render_max_fps 100, other than that there is no other methods to reduce workload. This setting also loaded from the .world file, so it may be overridden an you need to periodically check if the FPS limit is still applied. Thanks for replying, i have tried to put the viewport in the lowest setting, and yes i tried setting the max fps too, but that dosen't fix anything, i lowred all of the settings to lowest and even then it happens. the only thing which works is to put it's (the editors's) process on efficiency mode, which only fixes the heating issue for my laptop. I really hope that you guys would fix this issue in the next release... Edited April 27 by Umang.Raj 1
silent Posted April 28 Posted April 28 Yes, this is something we would like to investigate further and ultimately identify a proper solution for. Thank you for bringing this to our attention! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
shaman2010 Posted April 28 Posted April 28 Добрый день! Вам действительно стоит обратить внимание на эту ситуацию. Очень странное поведение - миллионы переключений контекста. LiveLock? P.S. Снизил fps до 10, и, по ощущению, теперь весь интерфейс editor-а рендерится с частотой 10 кадров.
