Runtime Commands
When In the Unigine Engine c# is there a way to have runtime commands
that change variables like floats.  I am not sure how to do this in Command
Hey! Could you clarify a bit what you're trying to achieve?
Are you looking to register custom console commands (so you can type something like `set_speed 5.5` in the engine console at runtime)? There's a Console class with an AddCommand method in Unigine C# that lets you register your own commands. More information here: https://developer.unigine.com/en/docs/2.21/api/library/engine/class.console#adding_command
If you could describe your use case in a bit more detail, it would help us give a more precise answer. Also, which version of Unigine are you using?
Yes, that’s exactly what I want to do with it, so I can set different values for things like "set_speed 5.5"
Version 2.21.0.0
Edited by CelloTapeGame
Thanks for clarifying!
You can use `Unigine.Console.AddCommand()` to register your own commands - the full details are in the docs
Basically:
- `Unigine.Console.AddCommand("set_speed", "description", OnSetSpeed)` — register in `Init()`
- Parse `argv[1]` as a float inside the callback to get the value
- `Unigine.Console.RemoveCommand("set_speed")` — unregister in `Shutdown()`
Spoiler
float speed = 5.0f;
public override bool Init()
    Unigine.Console.AddCommand("set_speed", "Sets the movement speed", OnSetSpeed);
    return true;
private void OnSetSpeed(int argc, string[] argv)
    if (argc < 2) { Log.Message("Usage: set_speed <value>\n"); return; }
    if (float.TryParse(argv[1], System.Globalization.NumberStyles.Float,
        System.Globalization.CultureInfo.InvariantCulture, out float value))
        speed = value;
        Log.Message($"Speed set to {speed}\n");
public override bool Shutdown()
    Unigine.Console.RemoveCommand("set_speed");
    return true;
Also, if you'd prefer a more visual way to tweak values at runtime, check out free Toolkit add-on on our store - it includes a Runtime Editor that might be handy!
  • Thanks 1
