in XML UI button
I am trying to attach a texture to my button but the button is taking the size of the texture and after applyng width and hieght , its not working correctly. I have attached the sample code for the reference. Please help as soon as possible , I am new to the unigine and this xml thing.
 <vbox align="overlap" width="400" height="44" pos_y="388">
                        <button name="HostButton" align ="overlap"  width="400" height="44" texture="UI/WhiteTexture.png" color="#F4B60D" background="1"  >
                            <text size="18" color="#000000">Host</text>
                        </button>
                    </vbox>
Edited by avnish.Gupta
private information shared in the ss bymistake
Hi!
Quick question - why are you adding a white texture to the button? If you just want to change the button's background color, you can do that directly with the color attribute without any texture:
<button name="HostButton" align="overlap" width="400" height="44" background="1" color="#F4B60D" pos_y="388">
</button>
If that doesn't help, could you describe what exactly you were trying to achieve with the texture?
If i want the button to be of specific image , right now its not the custom shape and all, In that case how i can do that?
Suppose i want this button . How i can attach that texture or any custom button
<hbox  align="overlap" height="44" width="400" pos_y="30">
                            <editline name="ScenarioEdit" align="overlap"  width="344" height="44" />
                            <button  texture="UI/RPA/GimbalControlRightArrow.png" align ="overlap" pos_x="356" width="44" height="44"/>
                        </hbox>
the image Button image is not coming proper and also the code you send
gives the below output image.png.c9bcd6f000c0e89392e28fefba5a52c7.png the test is not visible and one dark layer is coming . I will be attaching the complete .ui file. Please help me understand the tags more if i did something wrong in that.
<vbox align="overlap" width="400" height="44" pos_y="388" color="#F4B60D" background="1">
                        </button>
                    </vbox>
MainMenu.ui
Hey! We put together a sample project for you.
How to set it up:
- create an empty project
- arrow.png and button_texture_example.ui → put into data/
- AppWorldLogic files → put into source/
The sample contains 4 buttons:
1) borderless - button without the default engine border, text is optional. Done via <button> with background=0
2) bordered - same as above but with the engine border visible (background=1 by default)
3) resized - a textured button that can be resized. Done via a sprite with a transparent button on top
4) colored - same as resized, but with a color tint applied to the sprite via the color parameter
Important thing to know: when you set a texture directly on <button> via the texture= parameter, it cannot be resized - it always renders at full resolution like an icon. So if you want a resizable textured button, you need to use a sprite (which supports resizing) and place an invisible button on top of it.
Hope that helps!
button_texture_example.zip
How should one go about supporting multiple screen sizes/resolutions ? In the post I have attached a ui file where the dimensions and positions are fixed and if the screen size and/or resolution changes, they won't scale on their own. Is there a way to do this in the XML file where they auto scale and reposition as per the screen dimensions ?
Unfortunately there's no simple out-of-the-box solution for this in Unigine's XML UI.
There are two approaches:
  1. vbox/hbox with align="expand" - this can handle some auto-scaling, but honestly it can get quite tricky to configure and doesn't always behave as expected in complex layouts.
  2. The approach we use ourselves - handle resizing dynamically in code (AppWorldLogic), where you read the current screen resolution and set widget positions/sizes manually at runtime.
The second approach gives you full control and is much more predictable.
