CelloTapeGame Posted June 17 Posted June 17 Hi, anyone have a solution to this? Unigine 2.21.0.0 c# empty project. Fieldspacer is not removing water (ObjectWaterGlobal)
bmyagkov Posted June 18 Posted June 18 Hi, Could you please try lowering the ground plane slightly or turning it off completely? Thank you!
CelloTapeGame Posted June 25 Author Posted June 25 Hi I turned the floor plane off and it still does not remove the water from area in spacer
bmyagkov Posted June 26 Posted June 26 Hi, This time it looks like the "Field Spacer Enabled" flag is turned off on the ObjectWaterGlobal Parameters tab. Please see the attached video for reference. Thanks! 2026-06-26 10-35-00.mp4
