Amerio.Stephane Posted July 6 Posted July 6 Hello, I have this sv files for a setup with two screens attached, and I couldn't find any way to force the view_0 on display 0 to always be the one with the console. There is nothing like a "main_display" attribute in the sv. Switching view_0 with view_1 inside the file has no effect. And the button "Set as Main Window" in the spidervision window doesn't seem to save its effect.sensor2.sv
silent Posted July 7 Posted July 7 Hi Stephane, Looks like there is currently no option to make the window as "main". It's either the window where SpiderVision configurator is being opened or just a random window from SV. As a workaround try to set the main window via code to the desired SV window on start-up. Something like that should in theory do the trick: #include "AppSystemLogic.h" #include <UnigineComponentSystem.h> #include <plugins/Unigine/SpiderVision/UnigineSpiderVision.h> using namespace Unigine; <...> int AppSystemLogic::init() { auto sv = Unigine::Plugins::SpiderVision::Manager::get(); if (!sv) return 1; int target_id = sv->findViewportID("m1"); if (target_id < 0) { Unigine::Log::warning("SpiderVision: viewport \"m1\" not found\n"); return 1; } auto config = sv->getConfig(); for (unsigned int i = 0; i < config->getNumViewports(); i++) { auto viewport = config->getViewportByIndex(i); auto window = sv->getEngineWindow(viewport->getID()); if (!window) continue; bool is_target = (viewport->getID() == target_id); window->setMain(is_target); window->setHoldEngine(is_target); window->setConsoleUsage(is_target); } return 1; } <...> Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Amerio.Stephane Posted July 7 Author Posted July 7 2 hours ago, silent said: As a workaround try to set the main window via code to the desired SV window on start-up. That will do for now, but a saved option in the sv file would be great. Thanks! 1
