Marilou.Grignoli Posted July 15 Posted July 15 Hello, We are trying to accentuate the rotorwash "brownout" effect based on user feedback, but we have hit the limits of the vfx_turbulence_flow_dust.node with all parameters maxed out. Specifically, we are facing two limitations: - The effect doesn't start soon enough during descent. - The dust doesn't rise high enough to simulate a heavy brownout. Since we cannot modify the internal behavior of this node ourselves, what is the best way to achieve a larger and more controllable effect? Is it possible to get a modified node with extended limits ? Thanks for your help!
silent Posted July 17 Posted July 17 Hi Marilou, This should be feasible. However, we currently do not have the team capacity to take on this type of task. Achieving a stronger effect may also require setting up a new particle system. I believe we should be able to involve a technical artist in August to fine-tune the materials and configure the effect. Would that timeline work for you? Thank you! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Marilou.Grignoli Posted July 17 Author Posted July 17 Hello Silent, That works for us! August is a good timeline. If we can have everything good to go by the end of September, that will be perfect for us. I am available to discuss what the effect should look like if more description is needed. Thanks! Marilou
silent Posted July 17 Posted July 17 Hi Marilou, Thanks for the update! Two more questions: are currently on 2.21, right? And the second one: if you can provide us a bit more references (videos / photos) of what you are looking for -- that would be great! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Marilou.Grignoli Posted July 17 Author Posted July 17 Hi, Yes currently on 2.21. A short recap of the feedbacks we had : Dynamic Approach: The fast approach leaves a massive trailing wake of dust. When the pilot brakes, the downwash throws a violent "bow wave" of dust forward, which the helicopter then flies directly into. Early & High: The dust kick-up starts very early in the descent (way before touchdown) and billows violently upward, reaching higher than the rotors to swallow the aircraft. Zero Visibility: The particle density must be extremely thick and opaque. It should create a complete blind spot where the pilot loses 100% of their visibility. Here are some youtube videos that show a brownout : https://www.youtube.com/watch?v=5yanHiNMm7s https://www.youtube.com/watch?v=m9_P0_ebbXQ https://www.youtube.com/watch?v=AIQY1O2wXts And some pictures : Thank you again for your time and help on this! 1
