D.Contastin Posted August 4 Posted August 4 I am using Unigine 2.20. When my simulation is frozen (Unigine::Game::setEnabled(0), picture 1) we cleary see many raindrops but when I start it(Unigine::Game::setEnabled(1), picture 2), only few raindrops are visible and it is not acceptable. It is not a performance problem (FPS is displayed on right upper corner). When the simulation is running, I want the raindrops particle as visible as when the simulation is frozen. I can give you rain parameters if needed to resolve this problem. Thank Denis
silent Posted August 4 Posted August 4 Hi Denis, I'm afraid these parameters alone are not really helpful without a small test scene example with your content (it can be stripped / simplified) which combines the API settings + object + material. A particle system itself, it's parameters and texture are the key to the visuals. Which particle system are you using? You can always make a new one with more dense particles, reconfigure material, it's not locked to the some specific generic implementation. Also to make particles more visible in realtime 3D graphics we often use a hack and assign particle system directly to the camera and reducing it's radius to several meters. That will allow you to make more dense rain and still have some performance. Maybe you can also you this trick in your project? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
D.Contastin Posted August 4 Author Posted August 4 In your forum, Pierre Bultingare who worked on this project had this problem : the raindrops were too close to the camera, his tunned the distance from the camera too farway may be. I'll investigate. Thanks.
